Oziexplorer ny version (PC)
Inlägg av Lasse L » fre 20 jan 2006, 14:49
http://www.oziexplorer.com/
060120
History
Development Version 3.96.1a (January-2006)
The new features in this version required many internal changes to the software code. Please report any problems you find.
Fixes
Some bug fixes but probably added many more because of all the internal changes.
Changes
OziExplorer now supports skins which allow you to change the visual look and feel of the software. The Skin Manager is available on the File menu. 5 Skins have been provided, more will be made available in the future.
Many changes have been made to how tracks are handled. The concept of making track points active is now gone (they are now always active). Separate buttons are provided on the track control to add or insert track points to track 1.
The Track Control has had major changes, you can now make it any size, the list column widths can be altered and are automatically saved, the toolbar has changed to add new buttons and remove the buttons no longer needed.
The Track List has been changed and can now load large tracks instantly.
There are now numerous line styles for tracks. Use the Track Property dialog to set the line style. To open the track properties double click on a track in the track control list.
Points are now always active.
The Point Control toolbar has been changed to remove buttons no longer needed. The control can be resized but the column widths are not saved yet.
The Selection menu and Selection Control now has options to select track segments in Track 1 and points in Point Set 1. These options can be used instead of using active points to delete and save.
Ny version 11 feb
Inlägg av Lasse L » lör 11 feb 2006, 14:29
Oziexplorer ny version 11 feb
Ver 3.96.2a
per båt
Inlägg av per båt » lör 11 feb 2006, 23:22
Hej.
Vad handlar det om? Finns översättning?
MVH per båt
Inlägg av Lasse L » sön 12 feb 2006, 09:18
Det finns en svensk Ozie sida
http://64.71.184.220/loc/swe/oziexp_swe.html
AIS OZIE
Inlägg av Lasse L » sön 05 mar 2006, 19:45
:) Provkört, kan hantera AIS info klart bättre än Seaclear
http://www.fendern.se/propeller/index.p ... entry71307
Svante
Inlägg av Svante » mån 06 mar 2006, 17:37
Hur ser de olika skin-settings ut?
Har kollat på demon men inte hittat hur jag ändrar det.
Svante
Inlägg av Lasse L » mån 06 mar 2006, 18:38
Gå in i \"Arkiv\", näst längst ner, \"Klicka\" på \"Skin Manager\" där \"fanns\" 5 olika att välja på.
I den senaste ver.3.96.2a har skinnen försvunnit, även \"Set markörlinje på position\" saknas.
I ver 3.96.1b fungerar ovanstående.
AIS har tillkommit, är inte helt klart, troligtvis kommer en ny ver. snart.
AISen är mycket bra, fast den inte är helt färdig.
Svante
Inlägg av Svante » mån 06 mar 2006, 19:00
Okay, det förklarar ju saken. Jag laddade ner den sista såklart.
Svante
Inlägg av Lasse L » mån 06 mar 2006, 19:12
:? Jag har \"tipsat\" Ozie om buggarna.
:lol: Ozie är ett mycket kompetent och prisvärt program men min favorit är TIKI
http://www.tiki-navigator.com/
Svante
Inlägg av Svante » mån 06 mar 2006, 21:22
Tiki har ju ett \"intressant\" upplägg men jag har lite svårt att ta mig över tröskeln och lära mig ett program till fullo om jag inte gillar det grafiska gränssnittet. I just Tiki:s fall lider det lite av \"mycket är mer\".
Personligen tycker jag att grafiken är för flashig och tar focus ifrån kartorna, de breda tonade rutorena tar mycket plats, muspekaren lever ett helt eget liv osv. Jag ser den stora nyttan av ett sånt här program i planeringsstadiet av rutten. då behöver man inte överdimensionerade menyer och linjer utan mer ett enkelt och kraftfullt gränssnitt som är busenkelt att använda så inte glädjen i planerandet övergår i frustration i hanterandet. Gärna då menyer och snabbkommandon som följer windowsstandard för snabb inlärning - åtminstånde för datavana personer.
Sen för de som har möjlighet att även navigera med datorns hjälp kan man ju ha ett \"navigationsmode\" som mer liknar en kartplotter, stora tydliga knappar, intelligent muspekare osv.
ja... sån är ja...
Ja, och snart måste jag nog bestämma mig för vilket program jag skall skaffa mig \"järnkoll\" på, har bara inte hittat rätt än - tror jag. Vill ha ett program som hanterar c-map och ev. rasterformat i samma utan att det kostar skjortan eller är sprängfullt med finesser jag aldrig kommer att använda. Tills vidare så får nog DLS duga med dess brister, editera waypoints i Microsoft Access :roll: ?.
Svante
Inlägg av Lasse L » mån 06 mar 2006, 22:52
Hej Svante
Jag har kört ett 10 tal olika PC navprogram.
Kunde man plocka \"godbitarna\" ur varje så fick man värdens bästa.
Tiki har några nackdelar men jag tycker fördelarna överväger.
Jag tycker att det är det enklaste och mest lättlärda programet.
Nackdel är att det inte är följer windows standard, saknar AIS (kommer så småningom), zoom med skrollhjulet och \"Head up\".
Problem med musen har jag inte sett.
Att skapa rutter är mycket enkelt \"bara\" klicka och dra till nästa brytpunkt.
De stora \"rutorna\" kan man ta bort, tryck på F12.
De stora siffrorna i rutorna gör det lätt att läsa på avstånd. (Sittbrunn till kartbord).
Man lägger själv upp vad som skall visas i \"rutorna\" (9 st olika) och vilken färg texten skall ha.
3 olika \"sjökortsfönster\" kan öppnas.
Enkelt att \"styra\" autopiloten, peka på båten tryck ner musknappen dra till målet, släpp och en brytpunkt skapas, några \"klickande\" och båten går dit. Den funktionen uppskattar jag mest.
Kört Tiki >2000 Nm förra året. Parallellt med Seaclear (för AIS funktionen) .
Är du ute efter ett program mest för att skapa rutter och brytpunkter, då rekommenderar jag Ozie som bla. kan \"prata\" Garminspråket.
Är det enkelheten och lätt att lära då är det TIKI som gäller.
Skall det var billigt då är Seaclear oslagbart.
ja ... sån är jag
http://medlem.spray.se/silvadahlin/lasse.htm
Inlägg av Lasse L » tis 06 feb 2007, 16:53
Ny version av OZIE 3. 95 6te feb 07
Ändrad för Vista
