9.55 m
2.98 m
4900 kg
Håkan Södergren
| Längd över allt | 9.55m |
| Längd vattenlinjen | 7.7m |
| Bredd | 2.98m |
| Vikt/Deplacement | 4900kg |
| Tillverkningsår | 1978 |
| Kölvikt | 2500kg |
| Akter | kosterakter |
| Skrovkommentar | Skrov och däck i sandwichlaminat med balsa som distansmaterial |
| Storsegel | 24m² |
| Självslående fock | 18.5m² |
| Genua | 30m² |
| Genua 2 | 23.5m² |
| Spinnaker | 82m² |
| Motor | Volvo Penta MD 11, Yanmar 2GM 18hk. |
Direkt till babord om nedgångstrappan finns bakvänt L-format pentry. På motsatt sida finns stickkoj. Salong med två längsgående soffor. Mellan förpik och salong finns toalett
| SRS | 0.888 |
| SRS utan undanvindssegel | 0.854 |
Peter Rozendal, Netherlands·21 jan. 2012
Se åsiktThe ship is very fast. There is no need to reef below 5 Beaufort, meaning full mainsail and 110% genua can be used. Is faster than the LYS-figure indicates. Boat goes quickly to one side, but remains at 25 degrees. Very good on upwind, keeps track. Withstands bad wx.
You feel save at the rudder. Living comfort for 3 adults at maximum. Good nav seat and effective kitchen. Plenty of stowing room.
Strongly built and safe feeling. Lots of ways to trim the boat. Standard bilge handpump, selftacking jib, rigid rig, backstays, build for speed and comfort. No osmosis after 30 years.
Found no real big improvement proposal up till now.
Harbour manoeuvres needs some feeling for the long keeled boat: let the boat do it for you by his inertion, do not try to override the boat in the harbour.
If you come across a Lord Helmsman, ask the owner if he really wants to sell the boat. Once a Lord Helmsman and you will not need anything else for years to come
Britt-Marie·26 juni 2003
Se åsikttuff båt med mjuk gång
utmärkt för 2 personer även på jorden runt segling
Ketil Skovgaard-Petersen·11 nov. 2002
Se åsiktVind : går bra i middel-stærk vind Sø : går bra i høj sø. Går fint bidevind i høj sø. Sejlføring : bære sine sejl (rulle genua 27m2 + stor på 24m2 ) til ca 10 m/sk.
Fint, om man er bara to personer.
Ligger meget stabilt, både i havn og på havet. Er solidt bygget og føles meget tryg. Segler fint sit Lys 1.06 op
Bovpropel, har afhjulpet ovenstående (i nogen grad) Ny motor ( Solé 26 ) Rulleforstag
Havne manøvre i snævre marinaer. Dels p.g.a. langkøl, dels p.g.a. at kølen starter ved mastefoden, er der uballance ved vindtryk fra siden, hvor den straks falder af for vinden. Ingen styring ved bakning.
Tryg og velsejlende båd. Nok lige i overkanten til en person. Har seglet ca.3500mil på 3 år. kontakt pr e-mail: ketil@skovgaardpetersen.dk
| 1 200 000 kr | 2002 | Färdigbyggd Sverigestandard |
BidraDela dina erfarenheter av Lord Helmsman med andra seglare
